To many uga duggas
149 views 14 replies 7 participants last post by  badbmwbrad
Next time you are thinking about using an impact driver on a drain plug or spark plug remember this .
I bought this unit during the summer with a known oil leak .
While I hoped this was not what I would find , it was going to be the first thing to check .
While I don't know any history it appears someone went gorilla on the drain plug and cracked the case .
#4 ·
Good job! The oil drain plug probably has tapered pipe threads. Clearly, someone over-torqued the drain plug.
Normally, just a bit of pipe thread sealant or Teflon tape applied to the threads and a small amount of torque would be sufficient to seal the drain plug.
#6 ·
Looks as if you made the best of a bad situation given the circumstances.
Reactions: KJSeller
#8 ·
not much surprises me anymore......like the gentleman who drained the hydrostatic oil on his Honda and replaced it with 30W.
#10 ·
I've said before that impact wrenches should be sold with loosening, or counterclockwise, rotation only. The user can spin the fasteners back on with a low(er) power screwdriver (example), and then torque by hand.
Ugga duggas are personal for me. Some years ago, during the annual State safety inspection, I had to pay for the replacement of several wheel studs on my truck, after the "technician" ruined them via negligent use of an air impact. They disclaimed responsibility, suggesting that I could've damaged the affected studs. I replied, truthfully, that the wheels weren't touched since last year's inspection appt., at that dealership.
No Joy, so I took one for the team that morning.
I know that time is money, but a service appt. shouldn't be treated as a NASCAR pit stop, FFS.
I learned a little while later, just by chance, that the employee in question was no longer employed by that dealer. I don't know if my episode was contributive, and I wouldn't have suggested termination anyway. It happened, though, so I hope a lesson was learned.
Impact wrenches have their place. Mine made rear strut replacement on Offspring's CUV a bit faster and easier. That said, once the old struts were removed, the impact was put to the side.
#14 ·
it's just amazing that someone used an air hammer on a snowblower to tighten something. just when you think you have seen it all.......
now when someone tells me they have done all the work themselves I ask so why are you bringing it to me......then I tell them sorry, ain't gonna work on it. it always takes twice as long to "fix" their repairs.
