Greetings,
As I mentioned in some of my other recent threads, I am now the proud owner of a Toro 1128 OXE (Model 38654, S/N 31000XXXX) 'sans' engine. I have bought an LCT 369cc snowblower engine online and will be mating them up.
The story I got from the PO, was that he used the engine for another need, but I cannot imagine he felt that this machine was his front-line piece of equipment. Functionally, it seems to be all there, but definitely needs some love. . . mostly rust removal, painting, and general lubrication.
We shall see.
My first check was the engine mounting holes/studs. Width-wise the existing studs are fine, but they are about 11/16" short on the depth (front-back). Additionally, it looks like the engine would really like to be mounted an inch or 2 more forward based on the crankcase & shaft dimensions. So, it looks like I'll be re-doing the mounting holes.
Here is a picture of my checking of the mounting hole pattern - engine vs. chassis.
This is my first hands-on view of a Toro PowerMax . . . and I had originally thought that the re-engineering from the PowerShift years thinned out metal and 'cheapened' the machine. After having to load/unload it and muscle this thing around, I am impressed with how heavy duty and durable this machine really is. H-E-A-V-Y . . . even considering it's a larger machine. . . and that's without the engine.
Since the engine will not readily mount, I think I'll test run the engine on a bench and then go about disassembling this machine for some restoration work.
I'm excited about the 11 HP, trigger steering, the joystick chute control, along with the light. I may add a tachometer and a few more lights, considering I have a 60 charger system on the new LCT engine.
We shall see.
