Helping a neighbor whose electric start stopped working. On disassembly, it looked like the brushes were well past their service life, and additionally cranking too long had heated the plastic ways the brushes slide in enough to deform one of them so that the brush was stuck.
I've found a source for the brushes, but I'm stumped as to how these starters were assembled. The brush holder assembly is screwed from the inside into the motor end cap; the whole assembly comes off the commutator as a unit.as a unit There are no outer brush holder screw caps.
I'm testing out using fine thread to pull back the brush springs and then cut and pull out the threads once the armature is slipped in----I don't have high hopes it will work, and I can't imagine how the factory assembly was done. Seems like a very poor design!
Any suggestions would be most welcome!!!!!
