1 - 20 of 41 Posts
They seem to have a thick grease in the auger gearbox but I've always put 90wt oil in them. Is that horrible? A friend got one and I may be advising him on maintenance.
Mine also had grease in it. I don't think it lubricates the gearbox as well as mine wore a brass ring on the top that was not getting any lubrication. Its quite possible that maybe they began with oil in them as they seem to have a spot to put some in but maybe they leaked and the grease was put it due to that fact. I wish I had a manual to see what that said was the correct lubrication type.
the owners manual i have on pdf says to use grease, it just doesn't say what kind
found it in the manual thats posted on the board, use mag1 grease
toro website says 7oz of mag-1 but everything i find for mag-1 gl-5 is an oil
Is this it?
i'm not sure i'll have to ask rob or roy , they both have an ope repair shop
Were you able to find out anything about that gear lube William?
well i hate to say it but i forgot and i was at the shop today. i've got to stop at bob's shop tomorrow so i'll ask then
Ok. Thanks William.
i reminded myself my re-reading this thread this morning
All the 521s I have seen have a grease in the gearboxes. I always tip them back and get as much gear lube in as I can. Maybe there's a particular method for greasing them besides opening them up?
rob says he used grease too, i just got home from the shop
I don't know about blowers but on riding lawn mowers that also get used for blowing snow so they're in the -20 stuff too, the manufacturers recommend "00" in a lot of the geared transmissions. I had no clue what it was and did some research. It's close to a liquid and just barely a grease. It seems to work great for lubrication as it will move around like a liquid on moving parts better than a regular grease will. If it can lube a transmission on a 800 pound machine pulling a 200 pound guy around the yard hour after hour, year after year it should be more than enough for an auger drive. :cool:
Prime Line 7-06612 - Grease, 00 3 | O'Reilly Auto Parts
Super Lube "00" Grease 9 Ounce Tube 770 127 | eBay
so when you put grease in them what do you use
Does anyone have an owner's manual or shop manual that gives instructions on how to fill the gear box?
I own a few Mantis tillers and they use 00 Lithium gear lube. You actually have'to open it up to check and fill it.
Discussion Starter #18
It looks like something thick in there. I don't know if there's a special way but I can't get grease in them and I'm not taking it apart so I just pour 80W-90 in till it's full. I don't care what Toro says, I don't like the idea of a grease so stiff that could be pushed off to the sides. If it leaks a little gear lube, ok by me. If there was a grease fitting I could hit with a grease gun and **PACK** the thing solid, that would be acceptable.
nooo, what brand and type of grease do you use
1 - 20 of 41 Posts
