I recently purchased the Toro 721E snowthrower and would like to make sure I've adjusted the cable on the handle bar correctly. It's pretty simple and I've been switching up and down to test the tension but I have a couple of questions. The manual says 1/16" - 1/8" distance between the handle and the control bar but the picture doesn't really indicate at which point you need to measure. When do you start measuring - when you begin to feel tension or after you've pulled the control bar all the way back?
Also, for a brand new machine (where the belt is new), I would think that the tension would not need to be that tight as the belt would stretch out more quickly. Is that the recommendation - leave it on the "looser" end? Or...just go with the right measurement (1/16"-1/8")? Clearly, the measurement is what they recommend, however, matching to what the manual indicates is not straightforward based on the picture. I also can't find any videos on the topic -- only changing the cable (but they don't show the adjustment!)
Thank you in advance! Frank in SE PA (Bucks County)
