8Greetings.
Long time lurker first time. Poster.
Older girl here. There is a issue with backfiring and sparks coming out the exhaust, which with some googleing said running rich.
I had this serviced and they added a carb kit and said the Governor linkage was wearing. I used it this past week worked well with the back firing
I tried to. Adjust the bottom brass screw on the carb and now. I can't seem to even get it to run for more then a few seconds
Any tips how to reset this jet and get it running again?
Note the motor is a flat head briggs and stratton
Welcome to SBF Bigtuna! :white^_^arial^_^0^_
That's a great engine and with a little TLC (and maybe some tough love), she should be running like a top again.
I tore into a 7hp in my Allis Chalmer's thread. There are quite a few videos on youtube as well.
here's a link to the service manual.
With that said, it's actually recommended in the old-school Owner's manuals for the owner to pull the cylinder head & clean the carbon off of the head & piston. (replace the head gasket while you're at it).
You're probably also due for a valve job...which sounds complicated but it's a fairly simple procedure if you're good with tools. You'll need a lapping tool (< $10 for the dowel-rod version), lapping compound, feeler gauges (to measure the gap between the lifter & valve stem) and I recommend using a Briggs and Stratton spring compressor for removing the valve springs. You can get away with screwdriver prying on a tecumseh, but the briggs springs are heavier-duty. In a nutshell, you move the piston a little past TDC and measure the clearance, carefully grind or file some material off of the valve stem until the top of the spec is reached (usually takes a few passes). Then you lap the valves....this will bring the valve clearance (lash) back down to the middle of the spec-range (max-min). Once lapped & the clearance is good for each valve, reinstall the springs/keepers, reinstall the breather cover (and get a new gasket), the head / head-gasket.
Pay special attention to the bolts...often times there are 2 sizes. On my '70 7Hp, the longer bolts went over the exhaust area. There's a special torque order and spec (see service manual above).
^^^ wordy post but you have all summer to read it :)
Oh...and I almost forgot, we like pics! :icon_whistling:
