1 - 3 of 3 Posts
My in-laws had this small snowblower that they could not get to start. I figured I could figure it out. I replaced the spark plug and cleaned the carburator, but that didn't work. I ordered a new carburateor and installed it, which I thought would for sure get the problem fixed, but no luck.
When I try to electric start the engine it just turns and turns. About every 10 attempts it sounds like it might have a little life in it, but still does not start.
Does anyone have any ideas of what else could be the problem?
I appreciate any suggestions.
Ck if the head bolts are loose may need a head gasket. If you have a good blue spark it shouldn't need a coil. Take the muffler off it maybe full of gas. Also make sure the cylinder and rings not frozen or scored up.
Could be lots of things. Check for a strong spark. Make sure the spark plug isn't fouled with fuel or oil. Low compression. Did you try a squirt of starting fluid?
1 - 3 of 3 Posts
