Hi. I have a Toro CCR 2400. It’s been running fine. I used it a few days ago and had a couple of backfires, but it worked with no issues. Now I can’t start it. It comes close, but then it will backfire. When that happens, it won’t get close to starting again.
Any advise is greatly appreciated.
Does this have the RTec 2 stroke engine on it? If so you may need to rebuild the carb. The things that stop a 2 stroke from starting are usually fuel related. Just to be on the safe side Id check the engine for spark first. If you want a manual you can down load it from Toro's website....
If the unit was sitting for awhile or stored with gas in it you might have some water. I've had a little luck tipping my single stage on its face and giving a couple pulls but better yet pull the float bowl and see what you got.
if you are looking for a manual for your machine you can get them ( download ) from the toro website
