1 - 20 of 23 Posts
· Registered
Grabbed this a while ago from the dump. Some paint and plastic fade, but really little rust, very solid, and a good candidate for a summer repaint ((though maybe not by me).
Finally got around to testing it. Starts up with fuel in plug hole and carb, but not getting any fuel by priming. Fuel lines should be replaced, probably new carb.
wondering, what makes this different from other Toros, and is it worth restoring?
· Registered
what's special about the power shift is... [wait for it]... the power shift feature:
you should at least get it running to the point to see if the power shift feature works, and whether or not the transmission is good (my understanding is that it does not use a friction disk).
i have owned and worked on multiple Toro single and 2-stage snowblowers over the years, but I stay away from the power shift models due to their complexity. i've owned a power throw 824xl which had the larger power shift bucket but paired with a 'normal' friction disk setup.
· Super Moderator
plus the powershift has a transmission not a friction disc setup. i have an 824 powerthrow and powershift, the powershift seems heavier. i would most likely restore it if it is working like it should but i like Toro's
· Registered
Discussion Starter · #6 ·
so, it looks cool, but what is the advantage of this feature?
· Premium Member
I never had a problem with EOD with any of my machines .... it is interesting to be able to shift the axle, but honestly, I see no advantage ... probably why it never took off ...
· Registered
I see a huge advantage. You almost see threads pop up yearly of people adding weight kits to there bucket. This would help allow the bucket to be heavy when needed or make it lighter when you are transporting or moving the machine. It works similar to tractor trailers and how you can slide the axle to change how much weight is put on the truck
· Premium Member
I see no advantage
It's similar to the dig mode on a Honda track machine or Ariens RapidTrak (Position 3) where the rear ends of the tracks are the only part on the ground and all the front end weight is on the skids...
Automotive tire Automotive design Automotive lighting Rim Alloy wheel
· Premium Member
It must have taken off because it had a 16 year run. If they still made them today they would cost more than a Honda. I am guessing somewhere north of 10 grand. Not to many people would pay that when you can get China tin for a grand.
· Registered
The Powershift couldn't be built economically enough to compete with the friction wheel transmissions. The only downside to them now is parts availability and by now the trannies often need cleaning and regreasing.....not an easy chore. I've got several Powershifts, and they are without peer for power and throwing slush stock.
1 - 20 of 23 Posts
