My grandson and I did my son’s Toro 924 Powershift augers today and had a little problem with the shear pin Auger hub spacers.
Firstly, we only found one spacer. Can they stick inside the auger shaft when removing the bolt and nut.
Secondly, we installed the bolt first from the top and then from the bottom installed the spacer hub and nut. A YouTuber said to slide spacer hub up to bottom of bolt head and then drop it into proper side of shaft.
The question is are there 2 different hole sizes on either side of auger? Does it matter if the spacer is on bolt head end or nut end?
Before we take it apart I would like to know what the proper procedure is.
