Tried back and forth, held with vice channel locks and used impact drill. No good, tube spinning. Cleaned exposed threads, applied liquid wrench, letting soak. Anything else??
I had a similar issue with my machine (it's a real shame that the oil drain tubes don't all have flats to put a wrench on). I used vise grips, but tried to grab some of the exposed threads and kept adjusting the vise grips until I could just get them closed onto the oil drain pipe. This spring I'm converting the oil fill tube to a flexible hose that Briggs & Stratton sells (p/n 1723165SM).Tried back and forth, held with vice channel locks and used impact drill. No good, tube spinning. Cleaned exposed threads, applied liquid wrench, letting soak. Anything else??
or the machine could have never been serviced at all. i have always found them very tight on any machine that has never had an oil change.In guess you didn't put the cap on? The prior owner did? And over tightened it?
My 2015 Ariens Platinum had a similar set-up and the vice grips needed a high pressure to prevent it turning. Ariens fixed that on my 2022 28 Pro Rapidtrak by having flats for a 12 mm wrench on the pipe and a depression in the flywheel cover for clearance on the 12 mm wrench. Here is a pic:Tried back and forth, held with vice channel locks and used impact drill. No good, tube spinning. Cleaned exposed threads, applied liquid wrench, letting soak. Anything else??
But make sure to use one with a detent in the closed position so that it can't accidentally open and drain out your oil unexpectedly.Another alternative perhaps might be to install a petcock for future hassle- free oil changes?
