Model numbers of blower & engine and pix would help. First thing I thought of was ignition. Check for dry plug then without prime try a shot of carb/flammable brake cleaner in carb. If ignition is ok it should run a few turns. If it does then you have fuel/air problem. If it worked last winter the carb may have plugged with fuel residue. Did you clean it or replace? Cleaning is more complex than most understand and a replacement can be the wrong one or defective. Read up on small engines and watch the many good videos on YouTube.
