At maximum engine speed of 3850 rpm, the alternator is being run at 3850 rpm ÷ 60 seconds/minute = 64 Hz. But at idle the engine is only running at 2150 rpm, or 2150 ÷ 60 = 36 Hz.
The alt's output freq is dependent on speed and
also the number of poles the alternator(magneto) has of course and you're spot on with your calc's, BUT only if there's one(1) pole!.....USUALLY, however, alt's typically have multiple poles and I'm not sure what OP has, but *my Ariens LCT EFI 369cc alt. has 5 poles for example, so my alt's freq @ 3850RPM is........
3850RPM (R/M) = 3850/60sec = 64 Rev's Per Sec (R/S)
5 pole alternator gives 5 Pulses/Rev = 5 P/R (seen below)
5 P/R * 64 R/S = 321 P/S (R's cancel) Pulses Per Sec = 321 Cycles Per Second (C/S) = 321Hz
Again, not sure what OP's alt is, but it's probably more than 1 pole and most likely similar to mine since he has a 2014 Ariens deluxe 30".......
And so for me and probably OP's, @ 3850RPM = 321Hz and @ 2150RPM = 179Hz
*Scope on my engine's alt output @ some arbitrary start up idle speed I was set at and that I had measured where as seen.... t ~= 6ms and since 1/t = f, 1/(6ms) = 166.67Hz
Then as a sanity(mostly, but not always) check, converting this real measure freq of 166.67Hz back to real RPM's........(166.67/5)*60 = 2000RPM.
Trace #1 = Alt Output
Trace #2 = Spark Plug Pulse
@Butch1581
Note that the "peak" reading from the scope image above is about 20Vp which is around 14V RMS(typical DMM AC reading) as discussed in #1548 above.
This reading of 14V was taken running only @ around 2000RPM as measure with the scope, the alt. was mostly unloaded if I recall right.........You've measured "I only have 10.6vac coming off the stator at wot"?
If this was unloaded'ish, think it's a pretty safe bet to just neglect the DC side of things at whatever rate for now and simply say your AC just seems a bit too low for a properly operating stator's output and I'm pretty sure you have the same'ish 60W stator as I.
I just like this pic of my TB, so I put it here for no particular reason at all............Perhaps I'll just shall store it here.
