21 - 40 of 15780 Posts
Discussion Starter #21
i aired up the tires on the van, it was 39* but the wind chill feels like its in the upper teens so i passed on trying to start the toro 826
Discussion Starter #23
I replaced the scraper on my Toro Powerlite.
It took longer to get the tools out than to do it. 3 small bolts.
three small carrage bolts, even the ccr's are the same
Discussion Starter #24
a friend gave me a new plastic starter cover and i was out in the garage earlier seeing how it would fit on the toro 826. well its too long and will need to be cut to fit. i also found the right size bolts to mount the starter but i'm not sure if they are heavy duty enough for the job
Took apart my duel stage to get the augers unfrozen if possible.
Discussion Starter #26
went to costco this morning, from there i went to my mom's to share what i got from costco. did some vacuuming for her and took out the garbage before heading home. got on the board for a minute then thought about all the debris in my neighbors front yard from the tree falling the other day so i went out and cleaned her driveway and waklway as well as my own so if it snows i'm not debris from the tree
I checked over my NOMA Blowa. Made sure the chute would turn. I spayed the gear with WD-40 yesterday, when it was warm. Got some gas for it, too. Got some Kerosene for the heaters. I sprayed the roof rake, too. Can't hurt. We are supposed to get 6-10 inches tonight. It's 18 degrees out, right now, so I know it will move easily. In that kind of cold, I know I won't. I'm hoping the wind is strong enough to blow it off the roof.
Worked on a drain set up for my basement laundry room sink. Sheesh, I wish it would snow, these inside jobs are getting boring.
Discussion Starter #29
i vacuumed :(
Discussion Starter #32
its been too cold the last few days to play in the garage but i did recieve some parts i had ordered so hopefully i can get the electric starter installed on the 826 early next week
Discussion Starter #33
its been snowing since around nine this morning but there is only about two inches of snow on the ground. its the light fluffy stuff and there was about an inch of it when i got home from work so i used a " plastic " shovel to clear mine and my neighbors property
Stayed home all day trying to thaw our water so we can get water to the house. I rather fight a frozen auger shaft than a frozen water line.
Started my 2nd semester of college this week!
(I was laid off from Kodak last Spring, after 17 years..im going back to college for a complete career change..going into Computer networking, Cisco routers, that sort of thing) So im in college again, 20 years after graduating from college the first time! ;)
Discussion Starter #39
Got done work. won 2 eBay auctions for snow blowers. Got a gear box gasket in the mail, and cut the bottoms out of plywood for nesting boxes. (for thoes that don't know what that is they are where chicken lay there eggs)
