21 - 29 of 29 Posts
i live about an hour and a half to two hours north of toronto,
generally speaking, our snow storms are 6-8 inches or less, im home most of the time, so i normally get out and plow it quickly,
but last winter we had a few storms where we got a foot or more overnight, and at that depth my current 5HP was basically useless, i would have to go on the slowest speed which might have paced me at 6-8 feet per minute, its too frusterating going that slow, id be faster shovelling.....if i go on a higher speed i could only cut maybe 3-4 inches of snow or else the engine would bog down, and i would have to stop, to let the engine come back up to speed,
i want something that can handle a foot or more of snow going at a reasonable speed, and not a snails pace,
I would think based on you being in the snow belt and looking for a machine that won't bog down in deeper snow that you may not be happy with the 208cc engine. I would recommend at minimum the 254 cc -7.5 HP unit. 8/24 is a common ratio for snowblowers.
The bigger the better馃槇.
If you find a deal on a Honda or Yamaha, 6HP will be fine.
CC to HP conversion chart for Ariens AX engines
Displacement / HP / Torque
136cc 4.0hp 7.5 lbs/ft
208cc 6.50hp 9.5 lbs/ft
254cc 7.50hp 12.5 lbs/ft
291cc 8.50hp 14.5 lbs/ft
306cc 9.0hp 15.0 lbs/ft
369cc 10.0hp 17.0 lbs/ft
414cc 12.5hp 20.0 lbs/ft
Good luck with your search
Discussion Starter #22
yes, im starting to think that also,
thanks for the chart, that is helpful
i think i want at least an 8-10HP
I found this, if you want the ultimate.
over 30 years old and many parts are NLA. I love mine which is basically good for only smaller areas like my deck but I also have a couple parts machines in case it breaks down.
same thing with the Honda's HS50-70 and 80 ( which is 8 horse ). critical parts are NLA
A very popular Honda that I have no trouble selling is the HS724. Great DoubleDuty snowblower. Good enough for driveways and berms but lighter with a 24 inch bucket for smaller areas. it's about 60 pounds lighter than the HS828 and HS928.
here is a HS724 .with the OP mechanical background he can pick up a good one for around $400-800 around here in summer, service it, and be done with for several years.
here is a HS724 .with the OP mechanical background he can pick up a good one for around $400-800 around here in summer, service it, and be done with for several years. View attachment 167368
So the HS55 is wildly overpriced? I myself took a second look just now and it is a tiny Honda, isn't it. I could use a tiny Honda as I have recently fallen into the Honda Harmony lawnmower and FG-100 rototiller clubs. I can sell my Ariens and get the Honda for a reasonable price after I talk sense to the seller. So I ask the experts: What is that HS55 reasonably worth?
where is this? Vermont? we are at Lake Tahoe. This time of year it's about 200-300. during winter 400-500 ( here) vermont may have a different market for Honda's.
Here is another Yammy, much better price if it runs well.
21 - 29 of 29 Posts
