1 - 20 of 28 Posts
Hi Everyone and sorry in advance for the long post. Brand new to the forums and would love your expert opinions. This will be my first snowblower and I did a lot of searching on here, but am still indecisive if I should get the 24" Compact or Deluxe. I live in the NYC area (Staten Island) and the past 4 years or so we have been getting some nice dumps, with the exception of this winter. The snow falls can range from 12" to 30+" for the year. Most average snowfalls are probably 3" to 6" at a time (I'm guestimating). I do live on a hill and part of my sidewalk is sloped around 11 degrees and my driveway about the same. It's a corner plot with around 75 feet of sidewalk and a 2 car wide driveway that's around 16 feet long.
Storage is not a concern for either snowblower and the Compact 24 will probably be more than enough for my needs, but part of me is wondering how it will handle the sloped driveway and sidewalk and how it will tackle the EOD build-up left by the plows. Plus the current model weighs 213 lbs according to Ariens' website which is 32.5 lbs less than the Deluxe 24. 32.5 lbs is a big difference in weight, but how easy is it to push 213 lbs with 1 wheel drive engaged? I understand I can lock both wheels, but will mostly be using 1 for maneuverability.
The deluxe appeals to me more because for the price it gives me a bigger engine and has auto turn. I probably do not need the auto turn, but feel that it will assist with the sloped sections and 245.5 lbs weight since both wheels to be constantly engaged.
What's the auto turn reliability?
I'm definitely buying an Ariens because the "white glove service" is available in my area. Just want to be sure I have no regrets with my purchase.
Which would you recommend?
hello andre, welcome to SBF!! I would get the deluxe, it never hurts to have a little more power
From a lot of reading as long as they have the polymer skids and setup right the auto turn is good, I have a older Ariens that they make a auto turn kit for so I ended up ordering it, Unfortunately it came in the day before the last snow storm LOL So will be installing it over the summer for next season. I would go with the deluxe
Too big, is always better than too small - unless it doesn't fit in a garage, or thru a doorway.
Unless you're talking bucket width which for me 24" is just the right size for getting into smaller areas to clear. Not too big and not too small.
Sounds like your mind is made up. Either blower will be fine. The auto turn seems to have a good reputation, however, if your driveway is uneven you might want to inquire about how that will effect it. Also, I personally always lock both wheels bc when only 1 is engaged it's much harder to keep it in a straight line.
Sent from my SM-J320V using Tapatalk
I have a compact 24 and a deluxe 24. The auto turn worked great for me. Deluxe has quite a bit more power. It chewed right through almost 30" of EOD after this last storm without a problem. I would go with the deluxe.
Thanks for all the opinions! I have been watching many videos and both seem very good. My reserved side says the Compact will be enough, but as a guy i always want more power and features. From the responses i guess i should go the Deluxe route. Forgot to mention that the driveway is concrete and has some uneven spots due to cracks so that can be a concern but i wont plow very close to a car. Also, i will be plowing a lot of the EOD buildup since we also park on the street so the Deluxe's power will certainly help. I'll probably compare the pros & cons for one more week and then place my order. Chances are it will be the Deluxe unless someone says otherwise.
Oh, is the size of the Deluxe really much more than the Compact? There are not many comparison photos online and none in the stores around me.
Sounds like me. Concrete driveway with cracks, two cars parked on road. The width is the same, but the deluxe is longer. I don't have any problem maneuvering around the cars. And the auto turn works great. The deluxe is about 14" longer.
OK, here is the "definitive" answer on the the Compact Ariens snow blower. I just helped a neighbor replace a sheer pin, and after we did it, he let me take his snow blower for a test drive. It is nice and light, and very maneuverable, but that is all I liked about it. It would not throw snow very far, and just felt cheap and I didn't care for it. I have a Toro 10 hp/28" which is about 10+ years old versus his 2 year old Ariens, and if he offered to trade even, I would not do it. A full size snow blower is the way to go, and do not invest in a toy. But, I may have a different situation than you, so it is your money, and your decision. Myself, I did not care for the Ariens Compact. I also have a 9 HP Ariens, and that is a great machine also - comparable to the Toro.
Discussion Starter #15
14" longer? That quite a bit more than I thought. For some reason I thought it was only 5".
Yes the compact has a much smaller bucket and a shorted smaller tractor section, Good alternative for limited storage area for it but I find the smaller snow blowers not as good at moving large amounts of snow.
Discussion Starter #19
So i'm 90% positive on getting the deluxe 24. The 14" length difference put me off at first although the extra power and auto turn are very very attractive. It will be overkill for my needs but better to have more than less.
The compact and even sno tek look to be very capable machines but i dont want traction and EOD issues.
I had the same decision to make in the fall when I decided to buy a snowblower. I knew a 24" was about all I could fit into the space I have for it in the garage so I was looking at the Compact and the Deluxe. I liked the idea of the Autoturn and also liked the idea of the larger engine on the Deluxe as I have a fairly steep spot going up my driveway from the street.
I only got to use the blower once this year, but I'm glad I got the Deluxe with the larger engine. No problems at all going up the driveway to clear it. It took care of the solidly packed EOD pile without any fuss once I got myself synchronized with the machine. It didn't go straight through it as it was really hard packed with a lot of heavy slush and ice, but once I got moving it took care of it relatively easy. The sidewalk was also half covered with the plow pile for its whole length and I was sure glad to have the Deluxe when going through that.
A neighbor across the street has an older Compact that took a little more time and work to get through the EOD and plow piles on his sidewalk. He has a fairly flat driveway so no problem there for him.
Good luck with whichever one you decide on. It sure beats shoveling.
1 - 20 of 28 Posts
