1 - 13 of 13 Posts
looking for parts specifically cables for transmission,not haveing good luck finding finding any info on this unit sears and craftsman really have poor support on this unit. anyhow i know its a long shot but anyone know where to find a manual on this unit model # 536-909400?.this snowblower seems built well and for the most part decent shape just needs some work 5 hp runs pretty good so i think its worth the effort. thanks also need tires and rims this modle came with hard tires would like to replace with pnematic
I believe I've got the transmission cables you need for this unit, with the end springs and roller guides. Measure the length of your cables so we can be sure these are the correct ones.
Thanks Grunt for the info ,i went to site the cables i need are not available thru sears any more,but the link for the manual was helpful think im gonna buy it.
the cable size is 26 in. with eye hooks on both ends if you have them ill buy them off you .
The right end looks the same, except that this one has a spring on it. The left end is different.....and now I see why.
The blower I parted out had two cables at the handlebars....one for the auger engage, and one for the drive. The transmission was lever shifted with a long lever coming from the gearbox. Doesn't look like what I have will work for you....
sorry i didnt get back sooner been working alot,but yes i think my cables are different the are two for the transmision push and one pull. thanks for looking maybe ill be looking u up for other parts soon as theres a few other parts i need....
Sorry to bring up an old post, I was wondering if any of you folks have extra tires for sale that the OP was describing? Its a now defunct Sears part (49453 Wheel Assy.)
Or do you know if there are some newer tires that would fit the bill?
OP, i have the full manual right here. If you need specific section, PM me and i'll take a few photos of the necessary pages!
Thanks in advance.
1 - 13 of 13 Posts
