I have a 5 year old yark work snow blower , in my case the impellor spins as well as the shaft however the augers will not spin. I checked the shear bolts on the auger shafts and they appear ok . I beleive problem is in the gear box which which drives both sides of the augers , But first things first back at the impeller there are two split pins that need to be removed to remove the shaft ..How is this done????? Other units you can hammer the pins out hower there is zero room to do that ..Thanks JIm
