1 - 20 of 29 Posts
What do you use to work on your push behind mowers and walk behind snowblowers? Do you throw it up onto a work bench? Have you custom made something? I'm looking for ideas on equipping my garage with a bench or something to use to make it easier to work on mowers and snow blowers
I use the plastic saw horse, and old doors with ratchet straps to keep it all together.
I was fortunate that the previous owner, had replaced the doors and put them in the attic over the garage.
i normally work on the ground but if i do need a outdoor work bench i drop the tailgate on my truck and use it as a work bench
Ah yes...By the looks of it, an old 1st generation dakota. Had two of them, they're great trucks.
+1 on using the tailgate of truck. At least when it's not cold outside.
When I'm in my shop, I pretty much do everything right on the ground and sit on a milk crate. I do, however, have an awesome folding table. Not a card table or anything like that, but something a contractor would use on the job site. It's quite study, has measurements printed right onto it. I'm not exactly sure what it's called but it comes in handy quite frequently
i use 2 saw horses with a piece of 3/4 inch ply wood on top and just throw it up on that
I do the same but seeing that I'm just outside of the garage the trunk of the mustang gets used as my second work bench
Awesome deal! Thank you for the suggestions folks! What's the weight limit on that lifting cart and how much did it cost you?
This is the one I have.
http:/t.harborfreight.com/automotive-motorcycle/lifts-stands/1000-lb-capacity-hydraulic-table-cart-60438.html
They also have a 500lb one that would most likely be good enough for snow blower repairs. They were out of stock when I went to get mine so I ended up with the bigger one. I really enjoy having it, I work on a fair amount of lawn mowers and snow blowers for people, and it makes the it a lot easier on the back. :rolleyes:
The added top makes it wide enough so stuff doesn't fall off the sides.
I work outside on the concrete patio, or in the gravel driveway.
Don't you ever lose small parts in the gravel? I have enough trouble with my concrete floor when I drop something, can't imagine trying to find something I the gravel
i hate when i am working on my truck when it is parked on the gravel section of driveway. it can be a nightmare to find anything small when you drop it which is why i usually commandeer the main paved section of the driveway when i need to work on my vehicle. my main work area is generally beside the house. i always work on small engines on the paved section of driveway even if i have to make space or move my truck to do so
I can lose a nut/bolt in a clean room:eek: 'Jever search for that **** washer you just had, only to find it on the magnetic tip of your tool:rolleyes:
work benches
I use my motorcycle lift for all my power equipment. It makes everything easier. I have lost count of all the uses besides the obvious as to it's utility.
I'm 53 and my back needs a break. I initially bought it for my Motorcycles maintenance needs of course.
I highly recommend one if you have the space.
I love the thing. :)
1 - 20 of 29 Posts
