It's a 3 year old machine that had substantial wear on one side of the pinion shaft where the chain gear spins.
It was greased annually as stated in the manual.
I replaced the shaft last summer and inspected it again last weekend. I only used it for one storm and It is showing some wear already.
I removed the drive in straight grease fitting and replaced it with a 90 deg. fitting for easier access without removing the wheel.
Has any seen the same issue? I'm using the recommended grease.
I bought the shaft at a local dealer. They said it was the only one they ever sold.
