This question comes up all the time here. "My snowblower won't start or surges , runs rough when started " First of all use the SEARCH function to read dozens of similar threads with your problem by typing in key words in search box. There are also Brand sub forums such as Honda, Ariens, Toro etc that pertains to your machine.
In some cases and it took several years to learn this even though I have cleaned and rebuilt hundreds of carbs? ( ya , I have too ,much time on my hands)
REPLACE THE GOSH DARN CARBURETOR !!!!!!!! ( ya, family site )
you know why?
1. Cleaning usually works for us regulars but we are dealing with mostly newbies here. Newbies are just gonna make matters worse.
2. The reason 90% of these no start , surging issues is OWNER NEGLECT! old bad gas and LACK of maintenance.
3. Most residential owners are neglectful when it comes to common maintenance . They will have the same problemo every year.
so just replace the carb with a $15 chinese one every couple years.
EASY-PEASY
To AVOID these issues it's best to ALWAYS use FRESH gas treated with a gas stabilizer like Stabil or similar . Start your machines once in awhile and if it is going to sit for a spell , before putting it away from last use shut off fuel valve and let it runs until it stalls.
It shouldnt have to be said that if you have old gas in the tank , siphon or drain it out before adding fresh gas. Most carbs also have a drain plug at bottom of carb and drain that also.
We have many members here that use these techniques and have had machines for decades WITHOUT the NO START , SURGING issues.
There are plenty of great videos on You-Tube showing the best way to start a snowblower that won't start or surges. Donyboy73 is a good one for instance. Other members will post links to some of the better ones.
you know why?
EASY-PEASY
