New Honda HSS928-TC didn't start on the first pull after a month of use.
6.3K views 19 replies 15 participants last post by  KaRLiToS
Hi,
I bought a HSS 928TC like 2 months ago and used it about 3 times for total time of less than 5 hours. I still haven't done my first oil change.
Today this morning I had to do a couple of things in the shed and decided to start my snowblower because it hadn't run for a whole month. Put the key in it, set full throttle and the choke on and pull. It didn't start on the first pull but only on the second.
Is this normal after a month?
The gasoline is Shell V-Power with 0% ethanol and I have a stabilizer mix to it.
#7 ·
Second pull for my HS928 every time so far after it has sat for a little while. After my last 2 blowers it seems like a miracle. No complaints from me!
And it uses way, way, way, WAY less gas too. I used it yesterday; it was dark in the shed and I couldn't see the gauge, but I had used 3 times before and had not filled it yet. I went out and started blowing snow, forgot all about the gas. I finally checked it today - 3/4 full! That's mind boggling. The snow amounts haven't been very much, so it's not working hard, but my old blowers would still have gobbled a tankful or two by now.
#12 ·
The Onan twin on my '74 Suburban usually starts with barely a turn of the key too. Now my Toro Powerlite, that's a different matter. It can be an exercise machine disguised as a snow thrower at times.
When you go through the motions of starting up your Honda, turn the key, choke, turn on the gas...don't be too quick to give the rope a pull, whether you drained the gas after the last run or not. Seems to make a difference with mine if I pause after turning the gas on.
#15 ·
I have NEVER been able to start my Hondas with less than 3 or 4 pulls. Keep in mind that they are stored in an unheated shed. Clean carb, fresh plug and stabilized gas and it still takes a few pulls because the oil is thicker (yes, I use whatever the recommended oil is). I think everyone who says '1 pull and it was 20 below!' is stretching the truth a bit.
#16 ·
Eh, two pulls after it sitting with the gas turned off is normal. Especially, if you turn the gas on and immediately start pulling. The fuel bowl is probably still trying to fill itself. Best bet, turn the fuel on, let it set a couple minutes, then try to start.
There is a chance that the fuel left in there evaporated over time.
Reactions: KaRLiToS
