I noticed last winter when replacing my IMPELLER that the drive bearings on the axle (where is comes through the chassis) and on the track drive plate needed attention. Quite honestly, they should have been done before last winter!
In getting to it this weekend I see evidence of so much slop- play that it was starting to wear the chassis at one location!
All four bearings are desperate need of replacement:
It appears that I need to purchase the flange AND bearing as one part number (they are about $40 each!)
I was able to press out the bearing from each flange and was hoping just to R&R the actual bearing and not have to replace the whole assembly.
I disassembled the friction disc to inspect closer. I am not sure how much meat a new disc has or if this needs replacing (please opine on its condition.)
Since it is apart I will replace:
I do not plan on (nor do I want to) replace the friction plate swing assembly but is there a recommended service of this item? That is, should I used a cleaner- de-greaser (i.e.: Brake-Kleen?) Should I take some emery cloth to it?
I noticed no turning abnormalities, but with it all apart, is there a way to check the differential? Do these ever need replacing? They cost about $120.
Last question: I plan on replacing the crimp nuts, but does best practices dictate to replace the bolt that holds the flange on as well?
