1,601 - 1,610 of 1,610 Posts
[Edit: LED technology has improved exponentially since this thread was started. Be aware that earlier posts may be somewhat outdated, and that you will likely find the most useful information in later updates. Y.R.]
In this thread, we'll talk about the do's and don'ts of LED headlight upgrades for your snowblower, and post videos and pictures of our successes.
There are many models of snowblowers that have a headlight circuit, In most cases, you can find a single wire that registers at anywhere from 12v to 20v AC (with no load) that is located somewhere on the engine, many times under the gas tank. Halogen lights are the typical light that comes with many of our snowblowers. Many of us want much more light than what the halogen bulb can give us, as well as better reliability than a halogen bulb. The search for something brighter and more reliable ends with the LED light. LED's (Light Emitting Diodes) are extremely efficient, very bright, and have thousands of hours of reliable use.
Since the lighting circuit is typically AC current at somewhere between 40-60hertz, if you just attach an LED light to the circuit you'll get pulsing light (think on and off 40-60 times a second) This is caused by the nature of an LED, because an LED is polarity sensitive, and has no warm-up or cool down time when compared to a halogen bulb filament, the LED will flicker noticeably. The flickering of an LED on AC current is mildly annoying to many people, but VERY annoying when you are attaching it to a moving object like a snowblower. An LED that is in motion when attached to AC current (for reasons I won't even begin to get into) flickers much more noticeably. To test this for yourself, take a strand of LED Christmas lights, plug them in, and then swing them in front of you at arm's length, you'll see a strobing or flickering effect.
You can see many LED headlight upgrade videos on youtube like this one, where you can definitely see the flickering or strobing of the LED's. You can see the effect the flicker has on the video camera, you get weird tracks that go from top to bottom of the video frame.
1. EXAMPLE OF IMPROPER LED LIGHT INSTALL- NOTICE THE FLICKERING
2. EXAMPLE OF YET AGAIN AN IMPROPER LED LIGHT INSTALL- NOTICE THE FLICKERING
This is what it looks like once you add a bridge rectifier, even though you’ll see a tiny bit of flicker in the video, in person there is none, you also can notice that there is no “tracking” effect like in the other videos.
The problem of light flicker is solved by using a full wave bridge rectifier.
A bridge rectifier takes AC current and changes it into DC current using 4 diodes.
By connecting the positive and negative from your LED light(s) to the DC output of your bridge rectifier, and then connecting your single headlight circuit wire to one of the AC inputs of the bridge rectifier (it doesn't matter which AC input) and then attaching a wire from the metal of your snowblower to the other AC input you will have light! For safety purposes, it is recommended that you place a fuse on the headlight circuit wire before the bridge rectifier which should be about 5 amps rated fast blow, and then a fuse on the positive wiring between your bridge rectifier and your LED light that should be about ~1amp fast blow fuses. These fuse ratings are assuming you are using a headlight circuit that is rated for ~1amp at about 18volts, some headlight circuits are rated for 2, 3, or more amps, so using an amperage calculator like this one can help with both your LED light selection and your fuse selection. Volts/Amps/Watts Converter
Here's a pic of how I installed my bridge rectifier, I mounted it right next to my keyed switch that is on my handlebar console. I also used heat sink paste to couple the bridge rectifier’s metal casing to the console’s metal. I know this is way overkill, but my bridge rectifier came with the paste, and it was an easy application of some paste. The bridge rectifier I used is rated at 50amps 100volts KBPC5010 Bridge Rectifier | Alltronics
UPDATE: Using two 2200mfd 50v capacitors may be needed to clean up the voltage ripple that comes off of the DC output on your bridge rectifier. Some LED lights are sensitive to this ripple and may fail prematurely. Simply adding these capacitors in parallel on the DC output side of the bridge rectifier is a good precaution. Wire in the Capacitor(s) between the LED light(s) and the bridge rectifier. So the positive and negative of the bridge rectifier will go to the positive and negative of the capacitor. Then the positive and negative of the capacitor then get wired to the LED(s) positive and negative.
When choosing your LED lighting you typically have spotlights or flood lights available. Spotlights have a more pinpoint dispersion with very little side spill of light. Flood lights illuminate a wider area, and with the short distances (from LED light to relevant distance in front of your snowblower) you’ll want as wide dispersion as possible, or else you’ll get a tiny area in front of you illuminated. I made sure to get floodlights that were rated for voltage below what my snowblower headlight circuit tests at and above, so being that my snowblower headlight circuit tests at 18volts I picked a set of LED floodlights that were rated for 9-32 volts. I wanted to make sure that I would never be putting the floodlights in danger with whatever voltage the headlight circuit was producing, even a small voltage peak is accounted for. The floodlights I chose are 9 watts each, which is as much as my headlight circuit is rated for.
For those that appreciate a short(ish) video with some basic points noted here is a video.
https://www.youtube.com/watch?v=ZZwebMaiyBY
Great info. I was fortunate in that my Simplicity has DC voltage coming out of it.
I found a Briggs and Stratton kit to put LED's on my machine.
The kit part number is: 1688087
The kit part number is: 1688087 and I found a picture of the kit on a machine like mine.
lot has improved in 12 years. the sell ac/dc lamps now. no need for mods.
I didn't think that I knew that. A Simplicity parts guy that I spoke with in the process of finding that B & S kit said exactly what you are saying, that it didn't matter ac/dc. I mentally discounted what he had said and pushed it aside in my mind as the Simplicity is dc. So no surprise, you're right.
I did the math amperage wise as the hand warmers and the motorized chute rotation are both power hogs but the OEM light used an automotive fog light bulb that in itself drew a fair amount but thanks to LED technology it just passed.
Talk about a night and day difference (no pun intended) I not only have tons of super white light, but no shadow from the chute anymore!
It works really great!
Thanks forum members for all you do.
I purchased a small sla battery and just plugging in a cheap trickle charger that I have. The lamp pulls a little over 1a which gives me approximately 3h runtime, more than enough for the amount I need to do. Just an option if it works for you.
That's a simple, elegant solution for sure. (y)
That's a simple, elegant solution for sure.(y)
Sam Am I, following up with a “finished” snowblower in action that you guys helped
me get wired up this summer. I was
able to get the original headlight to work with a new LED light and an illuminated button. Works like a charm and gives enough light for what I need at the current time. I tore the entire snowblower apart and was able to free up the seized augers and save my differential and work gear too! Just have a few items left to address:
1) adjust the carburetor because it doesn’t run high enough and doesn’t throw snow like it used to. The tension pulley has already been adjusted too, so I hope that a carburetor adjustment addresses those issues. 2) need to figure out why reverse is soooo slow! It literally crawls. Figuring it’s the friction disc because the adjuster on the cable is already adjusted as
Much as it can be, but not sure about that one. 3) adjust scraper bar height. The blower pulls left and right and rarely goes straight and is a beast to steer as a result. I have to have some clearance for the bar because my driveway concrete is heaving and I have multiple 1/8-1/2” raised concrete lips that the blower catches “unexpectedly” and has caused many sore wrists and hips from running into the snowblower after it has abruptly stopped! Scraper bars are like $80 too! I’d like to save that thing as long as possible. Probably just a lot of tinkering on things and then needing some snow to try things out.
Thank you again for all of the help this last summer with the headlight wiring and other advice.
Just came across this. Great LED implementation.
I bought Arnold brand poly skid shoes and a side benefit they have because of their length is that they lift the blower housing before you get to that uneven expansion joint enough so that you keep sailing along.
@tabora is the go to guy on amperage type questions here. I don't know how much you can install on a Honda snowblower but I think he has an hour meter, heated grips , a light bar (led) and I think a couple other lights at the handlebars....he's ready for the zombies.....
not sure if it will run a heated coffee travel mug....or can make soup like we used to do in our big trucks....
I am debating using this light on my snow blower. My 30 inch craftsman professional series 247.88830has has 20 volts AC at where the halogen bulb is. It has hand warmers, but those are on all the time, no toggle switch.
So according to the specs of this light it would not require a bridge rectifier. Thoughts? I really don’t wanna do through to much wiring hassle. I’ve been using a battery light and I am getting tired of it. The stock halogen light is awful.
Hey raminator,
I did this modification on my Dad's old Craftsman (I think even the model number is almost exactly the same). Then, once everything else had rusted out, we moved the light setup over to his replacement Husqvarna blower and it was almost a direct swap.
I used a bridge rectifier because of the nature of AC power and the on/off sine wave power flickering you would get while using it. It was night and day, both literally and figuratively, between stock halogen and my 18W LED light setup (two 9W 6-led lights from amazon). It ran better with that light setup because there was not as much electrical power drain, even with me adding 3 toggle switches to have independent operation of each light.
I believe that this project is absolutely worth the time. And a benefit is that you could do a wiring diagram on paper first to walk yourself through it, making execution of the task easier. Follow-on thought, I used crimp / butt connectors to make it easier and faster on me for wiring, but now I would recommend connectors that slide together with a tape covering, or something more secure like actually soldering them. Again, I only had the couple hours that day to drive up and get the project done, so I went with speed.
I believe you can find my post on my profile. I'm away from home this weekend but can add it when I get back.
Just saw my snowblower (80's ST824) had provisions for lighting/electric set up. Put a multimeter to it and it put out power surprisingly (12-30v depending on rpm). I'd like to put some lights on it but it appears its ac only and I really don't want to do all the wiring/soldering needed to retrofit an led. Anyone put in one of the ac/dc led lights. Saw @harry398 was going to order something similar but never updated.
This led says it works with AC or DC. amazon led
