Predator 212 rejet
21K views 20 replies 11 participants last post by  Toro-8-2-4
Looking for some advice on what to use for the rejetting of a predator engine on a project of mine. I'd just as soon buy a jet and drop it in as opposed to attempting to drill the stock one out. Also will this add any hp to the mix? Forgive any possible ignorance, I'm just starting to learn about small engines. Thanks everyone!
#8 ·
Here is a supplier that sells jets at $2 each. The next available size up is .034.
When you drill to open the hole it is likely slightly over the drill size. If you do it by hand it may come out oblong.
BSP/Clone drilled main jet
From searching, it looks like the stock jet on the Predator (0.028) is too lean for cold weather snowblower application. Several have performed hand modification running a small 0.030 drill bit to rejet to 0.030.
The BSP site listed above now has 0.032 as an available size and next increment above the 0.028. Would that be a good option? I'd rather get one that exists then try to do this by hand.
This would be for Central New York weather, on a Ariens 10M6D repower.
thanks
#11 · (Edited)
That is a good point db130, you may get different results with vs. without the air filter.
MotorCity: Can you share if you kept the air filter in place when you went through your re-jetting experiences.
Snow blowers don't have air filters because if moisture gets in there it may ice up and you will have less or no air flow. Making it very difficult or impossible to run.
And yes, at BSP, the next largest jet size up from the .028 is .032. I stand corrected. Thanks!
#16 ·
Since you really are not going to use a snowblower at low engine speed, probably the low speed jet would not be a concern. (not even sure if there is one other than and air bleed ?)
I recently re-jetted my Predator 212cc on my Toro 521 . . it was originally 0.030 and I reamed it out to about 0.032. I have not been able to use it under load as the snow Gods have seemed to pack it in for summer . . . but you never know :)
#21 ·
I would leave the low jet alone for now.
I went through an evolution of using an .034 main jet to a .033 and now with the .032.
I find it runs great and less black build up on the plug.
I don't run with an air filter. In theory It should provide a bit more power.
I did try to open the pilot jet and it did not work out. Ran way too rich.
I went back to installing the original pilot jet and left well enough alone.
The only benefit I would see is helping with a cold start.
Right now if not run in a while it may take 7 or 8 pulls to start it. If I ran it yesterday it starts in one or two pulls.
I only run at idle speed when I get interrupted for a minute and don't want to shut it off. Other than that is always full speed.
I just accept all of this and it is fine.
If I were starting over I would get one of John's adjustable jets. It was not available when I did my repower. His oil adaptor drain is great too!
Good Luck.
