141 - 160 of 211 Posts
Discussion starter · #141 ·
When working in the shop I usually spend time looking for the 10mm socket that I used 5 minutes ago and somehow it has completely disappeared. Princess Auto has come up with a workable solution for 29 bucks. Now I will have to misplace all 10 of them before wasting any more of my time.
I had these in my hand the other day but before I got to the checkout the wifey called and said she was ready for pickup, so not wanting her to wait in the cold wind, I placed them back on the rack and left the store without buying them. I went back today and they were on sale for 19 bucks. Karma is still alive. Whoopee!!!
Discussion starter · #142 ·
If you are like me and end up working on old equipment you have probably run across some square headed nuts and bolts.
When I was younger I used an open end wrench or a pair of pliers to get them loose. Then I found a small set of 8 point socket to help me out.
It took me a while to come to the conclusion that 12 point sockets will work well to remove these fasteners as well.
It makes square head removal so much easier.
I have a couple of sets of Craftsman 8 point sockets. The one I use all the time is the 1/2" one for the big set screws on my dock leg brackets. SO much better than using adjustable or combination wrenches!
Toon, that was the set I referenced a few days back on Ziggy's workshop judging post, need to grab a couple sets of those......never have too many 10 mm s
The local Harbor Freight store had a sale on 4" magnetic parts trays for a buck a piece over the weekend. Regular price is $2 so not a real stretch even at not-sale prices. I filled my pockets, supplementing the stack of 6" ones I already have stuck to the car lift. Watched that video from Mammoth where he's juggling fasteners and other bits as he disassembled for a belt change in the deep snow. If I casually tossed a bolt to a glove sitting on the snow like that, I'd be out searching for it in the spring thaw. A magnetic tray keeps the pieces where you put them. For a buck or two each.
After doing a bunch of work on my brothers snowblower and lawn tractors, he bought this for me. I think he knows the state of some of his equipment is in. I hope it works like it does on YouTube. I think some of you on this forum have something like this. I’m sure I will run into some rusty nuts or pulleys rusted on shafts sooner or later.
Discussion starter · #148 ·
After doing a bunch of work on my brothers snowblower and lawn tractors, he bought this for me. I think he knows the state of some of his equipment is in. I hope it works like it does on YouTube. I think some of you on this forum have something like this. I’m sure I will run into some rusty nuts or pulleys rusted on shafts sooner or later. View attachment 212439
The nice thing about the induction heater is that it only heats the metal that is inside of the work coil and leaves all surrounding metal unheated and undamaged. Nice tool.
This is a cool thread to look through, I enjoyed looking at some of the tools. After 20 years in Tool and Die and CNC machining I have collected several thousand dollars in specialized tools for my trade. For those interested I’ll add some pics of of my collection, this is just a small portion of my collection. Sadly these tools just sit now, a couple years ago I took on a sales engineer position with a cutting tool company so I don’t I use them anymore. I’ll never get rid of them though.
Kozal,
I took one look at your photos and my first thought was that you have a huge amount of personal restraint. If you worked tool and die for 20 years and could still fit everything in a Kennedy Chest, you have way more self control than any person I ever met. :cool:
By the way, that is the cleanest set of tools and chest I've seen in a good long time.
Kozal,
Ha ha thanks, the mess is in my bottom box for sure and over the years I consolidated my tools. I also gave a few things away to the apprentices when I left. I kept the good stuff. 😉
Telescoping gages, now that's old school! Requires a good "feel" to use those. 👍
Yeah, guess gauges is what I called them. They can be pretty accurate in the right hands though. I was pretty good with them +/-.0005” or so, any tighter and I’d grab my bore mics or dial bore gauge.
Kozal01,
I have the same Shaviv tool and the Starett push punch along with pliers but that's all, I do have a better utility knife!!
CCMoe
I’ve used up several utility knives over the years, I tend not to pay much for them anymore. I used my pocket knife for most stuff anyway, it is always in my pocket. That’s a good segway to other tools, pocket knives. I have a handful that I rotate through, I’m never without one.
Discussion starter · #160 ·
Tools that haven’t changed much in the last 100 years.
For the sake of argument, let’s exclude anything that is simply a formed piece of metal—screwdrivers, sockets, and hammers—and focus on items with some kind of mechanism. Inventors are likely the first to tell you that perfection on the first or even the second try doesn’t happen often, but these five tools got awful close.
Ratchets
The first design of a ratcheting wrench was only capable of one direction. J. J. Richardson
The use of gears to create a one-way mechanism is old—over a century and a half. J.J. Richardson patented the idea of a ratcheting wrench in June of 1863 and, while his design appears archaic by modern standards, it relies on the same principles as the ratchets that sit in virtually every toolbox around the world.
Very different look, same function.
A center gear doubles as the attachment point for the socket. That gear interacts with two smaller ones that force it to spin either clockwise or counterclockwise. The direction of a modern rachet is easy to switch, and its gears have evolved to be much finer, minimizing the rotation required to grab the next tooth, thus making the ratchet more efficient in tighter spaces.
Bench vise
If you thought of one tool when you saw this article’s headline, it was probably this. History traces the bench vise back to the 1700s, but the first modern version was made of poured cast iron in the 1830s. The casting process was rudimentary, though, and resulted in a porous finished product that had the potential to break during use. Today, the best modern vises are forged.
Piston-ring compressor
To contain compression and combustion, you must put a seal on the piston; to do that, you must be able to compress said piston while you assemble it. Consider that Otto was experimenting with his designs in the 1860s, and it’s reasonable to conclude that our spring-form piston ring compressors trace to this time period. Not everyone uses these tools, but those who do know just how important they can be.
Scissor jack
As long as there have been cars, we have needed to lift them. While an incline plane (a ramp) effectively raises the car while the vehicle is on its wheels, a spiral incline plane combined with four metal arms and a base will lift a car from any point to allow you to remove wheels or other parts. That is the essential form of a scissor jack: A screw that pulls together two arms that provide lift.
The design traces back at least 100 years and it is nearly comical how little has changed from the patent drawing to the folded-metal jacks found in the trunks of so many modern cars. Jacks and spare tires might be falling by the wayside, but the simplicity of a scissor jack will stand the test of time, even if it has never passed the test of safety with flying colors.
Vise grip
The main thing we need while working is a third hand, something that can hold our workpiece together or give us a handle on something otherwise untouchable. The over-cam design for locking jaw pliers might be the youngest one on this list: 99 years have passed since inventor and blacksmith William S. Petersen penned the design that became the nearly indispensable tool we know today. The easy-release lever was added in a slight redesign by Petersen in 1957 (above).
