121 - 140 of 211 Posts
I keep one of those cheap interchangeable-bit screwdrivers handy, the orange ones from Harbor Freight. They double as nut-drivers in 1/4" and 5/16"-8mm sizes with the bits removed.
I have picked up a lift cart and add a wider and longer top to it. As well as supporting legs for loading a blower on it in conjunction with a ramp. I have now used it on three different machines and I find it very nice not having to kneel or Crouch down. This has work really well for greasing the rakes on a two stage.
I find these very useful,
I use these transfer punches quite often.
transfer punches | McMaster-Carr
These little transfer points are invaluable when marking threaded holes. Set the point in the hole, lay what ever material you want to mark, tap the material and you have an exact point. No more measuring twice!
transformers | McMaster-Carr
Use the all the time as an extra set if hands while working alone.
Clamps | McMaster-Carr
CCMoe
Maybe not to odd…..
This is a Pexto 6” Monkey Wrench, it was given to my Dad when he started work at the Charlestown Navy Yard (Boston) during WWII. He was a pipe fitter / fabricator and on day one, they passed out handbooks (I have it somewhere) with the general rules (Including don't talk to friendly women, they may be Nazis, etc…) a box of tools and a Stilson wrench.
I cleaned it up, made a new handle for it and it's ”worked” on my desk ever since. The original patent was listed by Peck, Stow and Wilcox Co (later became Pexto) in the 1800s. I can only imagine what repairmen thought when they first saw this tool...a wrench that adjusts, must have been someone's go-to tool.
For a newer tool that, while a one-trick pony, does the job like nothing else… here's a rivnut tool that solved a “how am I going to mount that?” problem more than once. I never knew such a thing existed, until I stumbled upon it looking for speed-nuts.
Reactions: CCMoe and Beanhead
Catch 22
I have a couple hand ones, looks like a rivet gun. We use the at work on dorm room windows.
Marson 39001 Marson HP-2 Hand Rivet Kit | JB Tools
They open up some different options on fastening.
CCMoe
Catch 22
CCMoe
Yes it does… I saw the hand models, but since someone gave me an Amazon gift card… the air power version was mine. I don't use it enough to justify it honestly, but man it works effortlessly. I lend it out, so someone is always happy when I say…hmm, I might have a tool that can get you out of that.
Belongs in the wish I had it years ago category.
Reactions: Grunt
Catch 22,
It's a game changer. We use then to repair the arms on a hopper window in dorms, a few other applications on campus.
CCMoe
Discussion starter · #131 ·
This one is its smaller brother. I acquired it with a bunch of old tools from a mechanic who worked way back in the 1970s. The moving jaw is better supported than our current adjustable wrenches so the jaws stay better aligned and are less likely to strip the bolt head. I try to avoid using adjustable wrenches at all times, but sometimes they are handy when you don't want to carry around multiple wrench sizes. The overall length of this one is only 4 1/2" but the throat opens up to over an inch wide.
Discussion starter · #134 ·
TOOLS EXPLAINED BY PETER EGAN
DRILL PRESS : A tall upright machine useful for suddenly snatching flat metal bar stock out of your hands so that it smacks you in the chest and flings your beer across the room, denting the freshly-painted project which you had carefully set in the corner where nothing could get to it.
WIRE WHEEL : Cleans paint off bolts and then throws them somewhere under the workbench with the speed of light. Also removes fingerprints and hard-earned calluses from fingers in about the time it takes you to say, 'Oh sh*t'
DROP SAW : A portable cutting tool used to make studs too short.
PLIERS : Used to round off bolt heads. Sometimes used in the creation of blood-blisters.
BELT SANDER : An electric sanding tool commonly used to convert minor touch-up jobs into major refinishing jobs.
HACKSAW : One of a family of cutting tools built on the Ouija board principle... It transforms human energy into a crooked, unpredictable motion, and the more you attempt to influence its course, the more dismal your future becomes.
VISE-GRIPS : Generally used after pliers to completely round off bolt heads. If nothing else is available, they can also be used to transfer intense welding heat to the palm of your hand.
OXYACETYLENE TORCH : Used almost entirely for lighting on fire various flammable objects in your shop. Also handy for igniting the grease inside the wheel hub out of which you want to remove a bearing race..
TABLE SAW : A large stationary power tool commonly used to launch wood projectiles for testing wall integrity.
HYDRAULIC FLOOR JACK : Used for lowering an automobile to the ground after you have installed your new brake shoes, trapping the jack handle firmly under the bumper.
EIGHT-FOOT LONG DOUGLAS FIR 2X4 : Used for levering a car upward off a hydraulic jack.
TWEEZERS : A tool for removing Douglas Fir splinters.
PHONE : Tool for calling your neighbor to see if he has another hydraulic floor jack.
BAND SAW : A large stationary power saw primarily used by most shops to cut good aluminum sheet into smaller pieces that more easily fit into the trash can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST : A tool for testing the maximum tensile strength of everything you forgot to disconnect.
PHILLIPS SCREWDRIVER : Normally used to stab the vacuum seals under lids or for opening old-style paper-and-tin oil cans and splashing oil on your shirt; but can also be used, as the name implies, to strip out Phillips screw heads.
STRAIGHT SCREWDRIVER : A tool for opening paint cans. Sometimes used to convert common slotted screws into non-removable screws and butchering your palms.
PRY BAR : A tool used to crumple the metal surrounding that clip or bracket you needed to remove in order to replace a 50 cent part.
HOSE CUTTER : A tool used to make hoses too short.
HAMMER : Originally employed as a weapon of war, the hammer nowadays is used as a kind of divining rod to locate the most expensive parts adjacent the object we are trying to hit.
UTILITY KNIFE : Used to open and slice through the contents of cardboard cartons delivered to your front door; works particularly well on contents such as seats, vinyl records, liquids in plastic bottles, collector magazines, refund checks, and rubber or plastic parts. Especially useful for slicing work clothes, but only while in use.
1/2" x 16" SCREWDRIVER : A large motor mount prying tool that inexplicably has an accurately machined screwdriver tip on the end without the handle.
BATTERY ELECTROLYTE TESTER : A handy tool for transferring sulfuric acid from the battery to the inside of your toolbox after determining that your battery is dead as a doornail, just as you thought.
E-Z OUT BOLT & STUD EXTRACTOR : A tool that snaps off in bolt holes and is ten times harder than any known drill bit.
GREASE GUN : A messy tool for checking to see if your zerk fittings are still plugged with rust.
ADJUSTABLE WRENCH: aka "Another hammer", aka "the Swedish Nut Lathe", aka "Crescent Wrench". Commonly used as a one size fits all wrench, usually results in rounding off nut heads before the use of pliers. Will randomly adjust size between bolts, resulting in busted knuckles, curse words, and multiple threats to any inanimate objects within the immediate vicinity.
Son of a b*tch TOOL : Any handy tool that you grab and throw across the garage while yelling 'Son of a b*tch' at the top of your lungs. It is also, most often, the next tool that you will need.
Reactions: Jklightner
have one just like this. got at garage sale for 5 bucks.
Reactions: ToyFamily
a truer post I never ever seen.
Reactions: JJG723
Discussion starter · #138 ·
When working in the shop I usually spend time looking for the 10mm socket that I used 5 minutes ago and somehow it has completely disappeared. Princess Auto has come up with a workable solution for 29 bucks. Now I will have to misplace all 10 of them before wasting any more of my time.
One of my first big purchases was a JD2 tubing bender. I still use it constantly 25yrs later. I’ve added a Ram instead of hand power and more die sizes.
This Husky tool set has lasted 15yrs. Working in several shops and mobile. I have a tool box full of sockets but I usually go for it first and always have it in my truck. This case has helped me keep all but one socket in all those years. 😬
Below is a wide range…Solid modeling is a huge advantage in many things I do. The fixture table is used daily since I got it and won’t go back. My welding hood is not my first but 15yrs old and hand pinstriped by a friend.
Fireball precision shims…they’ve replaced a rack of scrap metal to shim projects. I use them daily, quickly bought a second set. 🙌
Discussion starter · #140 ·
I'm guessing that your livelihood has a good degree of fabrication in it. I have used all of these tools but in a different capacity I think than you use them.
We used an Enerpack pipe bender back in the day for bending conduit. I love your lay out table, and your precision shims are like the fabricators version of a gage block set used by tool and die makers. I think quality work comes out of your shop.:)
