Where do you find spark plugs inexpensively?
1 reading
7.1K views 21 replies 16 participants last post by  Toro-8-2-4
I’m looking for an online source, but right now it’s Walmart for champion and tractor supply for NGK.
#2 ·
Amazon has alot. But personally I buy locally. Because I can get them right now when I need them and usually about the same price.
Sent from my SM-G973W using Tapatalk
#4 ·
Pretty much what Savage420 said. Spark plugs aren't that big of an expense and I don't use so many of them that cost is a consideration unless the price is so out of line it annoys me enough to make me go somewhere else.
#5 ·
I usually order off the shelf parts from the chain auto part stores. When you go to their websites, a banner pops up, usually for 25% off.
I buy online an pick up in store using the percent off cupon. Pretty slick
#8 ·
No, no China plugs, I ask because I repair on the side and buy them all the time. The cheaper I buy is better for bottom line for me and customer. Walmart is fine but they always run out of the popular plugs
#22 ·
Unless you are buying a large quantity at once you will get the best price at your local Walmart or auto parts store. Even cheaper than Jacks or any online store. And Fast!!! Make sure you cross ref MFG numbers to a Champion, Autolite or NGK. Sometimes that is tricky but you can usually do some googling and figure it out.
#9 ·
The tough part is, you could be getting China spark plugs without even knowing it:
In the past I've bought most of my spark plugs on Amazon, but having seen that video, may be more selective in the future.
#11 ·
Yeah, I got stuck with counterfeit NGK plugs via Amazon earlier this year. In all my years, I've never had a spark plug failure until now.
#12 ·
What was the failure in, a car or equipment? I ask because I may take the advice of counterfeit for a vehicle but may take the chance for a snowblower(if for some reason it came down to having to buy from amazon)
#14 ·
I can not even remember the last time I needed to buy a spark plug.
Even many of my machines from the 70's still have originals in them …. :)
#20 ·
I hardly change plugs. Brass wire brush or wheel and a little compressed air and a re-gap.
If I do it's because rust or it's really old looking or maybe someone put one of these cheap e3 plugs in it. When I do buy them. I buy a case at a time. Flat heads I use Champion and everything else I use NGK. I usually buy bulk packs that hold I think 24 pcs. I only will buy from a small engine dealer. If you have someone you have a good relationship with they can give you a competitive price.
