Mower: Craftsman 625 with BS engine. Your typical 22", push, high-wheeled push mower. About 20 years old, very good condition. Cutting lawn at 9,500 feet altitude.
I put a new carb on it this spring and still performs strong, but I work it hard in 8-12" cuttings on occasion if I let it grow too long before I can get to it. Kit included new: carburetor, spark plug, air filter.
I will fill the tank and run it to empty (stalling.) This will me give about 60-80 minutes of cutting. I'll take a break, get some water and sit for a while to catch my breath.
After this 20 minute break, I'll come back, fill the tank and attempt to complete the cutting. But the thing will not start! I prime the carb only a few pumps out of fear of flooding. 4 or 5 pulls later I will prime a couple more pumps. No-go so a couple more pumps. At this point I figure the bowl has enough fuel and I prime no more- Yet it will not start!
When it is fully cold (not running at all in the same day), I will give a shot or two of starting spray and it fires up on the first or second pull. I have not used starting fluid in the situation described above in the re-start scenario. I figure it is not cold enough to warrant it.
I must mention that this situation occurred with the old carb as well. I only replaced with the new cheapo $20 dollar carb because it would not start at all when cold.
With this new carb, it is very similar to the old:
Any ideas or comments?
- Starts up fine
- Performs (cuts) great
- No start after running dry and refilling
